I now received some relays. It's time to characterize them !
Coil resistance : 35Ω
Coil inductance : 28000µH
Latching : 2V@0.06A (120mW ±20%?)
Release : 1.1V@0.04A (44mW ±20%?)
They are sold as 2.8V and I tested them with no load, I don't know how much current they can withstand. Anyway, switching 16 relays will draw 1A.
The coils look very compatible with the tiny incandescent lamps !
if u have measured coil res as low as 38 Ohm, then u got PC4.591.005 or PC4.591.12 good luck!
Hi. They are 0.2A DC max. Made for commutation 50 to 400 Hz. thats description, but in Russian http://lib.chipdip.ru/248/doc000248413.pdf
Thanks !
Those are some cute relays :) What is their 'normal' application?
surviving the Soviet era has been one of its successes...
Cool! My ferrite cores are ex-Soviet also
