So I bought a Sony UP-DR200 dye sub printer to go with this. I had a hell of a time getting the drivers installed. So, I found a great script and modified it so that it just installs Cups and Gutenprint. If you're stuck with getting print drivers installed, even if its not this one, check it out here: https://github.com/DoctorLar/raspberry-pi-Cups-Gutenprint.
I CAN PRINT!!!!! That took an entire day. Crazy. I found an excellent install.sh file that another guy wrote for some instagram stuff. I'm testing the mod and will post. With just a few steps, it will load the current Cups and Gutenprint.
