Working on a new version of the kernel module - here. Also tried a new version of th pulser.. a plastic tube stuck on the transducer. Helps to fix a point at a fixed distance, see below:
![](https://raw.githubusercontent.com/kelu124/echomods/master/alt.tbo/20171001a/20171001_135041.jpg)
The results went well:
![](https://raw.githubusercontent.com/kelu124/echomods/master/alt.tbo/20171001a/Pulses_average_Tube.jpg)
Read more about the experiment on the gitbook.
