Arduino Source Code
A project log for NodeLP - Low power solution for DIY Sensor
NodeLP is designed for low power sensor node.Use it with any board such as Arduino, ESP8266, CC3200, CC2541 and other WiFi, BLE dev boards.
michael-wenMichael Wen • 07/07/2016 at 15:37•0 Comments
#include <avr/sleep.h>
#include <avr/power.h>
#include <avr/wdt.h>
#include <EEPROM.h>
// Utility macros
#define adc_disable() (ADCSRA &= ~(1<<ADEN)) // disable ADC (before power-off)
#define adc_enable()  (ADCSRA |=  (1<<ADEN)) // re-enable ADC
#define BODS 7                     //BOD Sleep bit in MCUCR
#define BODSE 2                    //BOD Sleep enable bit in MCUCR
/** the current address in the EEPROM (i.e. which byte we're going to write to next) **/
int addr = 0;
#define LED_PIN (13)
#define USB_PIN (9)
volatile int f_wdt=1;
 *  Name:        ISR(WDT_vect)
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Watchdog Interrupt Service. This
 *               is executed when watchdog timed out.
ISR(WDT_vect)
  if(f_wdt == 0)
    f_wdt=1;
//  else
//    Serial.println("WDT Overrun!!!");
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Enters the arduino into sleep mode.
void enterSleep(void)
  //set_sleep_mode(SLEEP_MODE_PWR_SAVE);   /* EDIT: could also use SLEEP_MODE_PWR_DOWN for lowest power consumption. */
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  /* Now enter sleep mode. */
  sleep_mode();
  /* The program will continue from here after the WDT timeout*/
  sleep_disable(); /* First thing to do is disable sleep. */
  /* Re-enable the peripherals. */
  power_all_enable();
 *  Name:        setup
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Setup for the serial comms and the
 *                Watch dog timeout.
void setup()
  //digitalWrite(0, LOW);
  //digitalWrite(1, LOW);
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, LOW);
  adc_disable();
  // turn bod off
  // bod consume 22 uA
   MCUCR |= (1<<BODS) | (1<<BODSE);
   MCUCR &= ~(1<<BODSE);  // must be done right before sleep
  int val = EEPROM.read(addr);
  if(val==255){
    EEPROM.write(addr, 0);
  //Serial.begin(9600);
  //Serial.println("Initialising...");
  //delay(100); //Allow for serial print to complete.
  //pinMode(LED_PIN,OUTPUT);
  /*** Setup the WDT ***/
  /* Clear the reset flag. */
  MCUSR &= ~(1<<WDRF);
  /* In order to change WDE or the prescaler, we need to
   * set WDCE (This will allow updates for 4 clock cycles).
  WDTCSR |= (1<<WDCE) | (1<<WDE);
  /* set new watchdog timeout prescaler value */
  WDTCSR = 1<<WDP0 | 1<<WDP3; /* 8.0 seconds */
  /* Enable the WD interrupt (note no reset). */
  WDTCSR |= _BV(WDIE);
  //Serial.println("Initialisation complete.");
 *  Name:        enterSleep
 *  Returns:     Nothing.
 *  Parameters:  None.
 *  Description: Main application loop.
void loop()
  if(f_wdt == 1)
    //int ret;
    /* Toggle the LED */
    //ret = digitalRead(LED_PIN);
    //digitalWrite(LED_PIN, !ret);
//    if(ret==HIGH){
//      digitalWrite(USB_PIN, HIGH);
//      delay(100);
//      digitalWrite(USB_PIN, LOW);
    val++;
    if(val>23){
      delay(7000);
    }else{
      EEPROM.write(addr, val);
    /* Don't forget to clear the flag. */
    f_wdt = 0;
    /* Re-enter sleep mode. */
    enterSleep();
  else
    /* Do nothing. */
