Hackaday.io Hackaday.io
Sign up Log in
Warhammer 40K HANDGUN
This pistol goes perfectly with any Imperial Warhammer 40K cosplay, prints easily without any supports,
esrarengiz1984esrarengiz1984
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 10
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
953
0
2
3
Team (1)
  • esrarengiz1984esrarengiz1984
Join this project's team
  • Warhammer 40K HANDGUN
completed project
MISC
warhammer Warhammer 40000 warhammer 40k handgun weapon gun 3d printing 3d model printed 3D printed 3d printer
This project was created on 03/28/2018 and last updated 8 years ago.
Description
This pistol goes perfectly with any Imperial Warhammer 40K cosplay, prints easily without any supports, is fun to paint and has a suprisingly nice balance when handled.
The way it was split ensures it will fit on any regular desktop printer and in addition makes clean painting as easy as possible.
https://www.youtube.com/watch?v=RfR9J6lsFNI
Print settings:
print at 0.1 - 0.2mm layers (I printed everything at 0.15mm)
3-4 perimeters
30% infill
no supports needed * Grip: You can either print "grip_full.stl" vertically (will require minimal supports) or print the two grip halves ("grip_1.stl" & "grip_2.stl") and put them together with the dowels and some glue.
Details
Files
triggerguard_1.stl
Standard Tesselated Geometry - 796.08 kB - 03/28/2018 at 15:07
Download
magrelease.stl
Standard Tesselated Geometry - 109.07 kB - 03/28/2018 at 15:07
Download
trigger.stl
Standard Tesselated Geometry - 68.15 kB - 03/28/2018 at 15:07
Download
grip_full.stl
Standard Tesselated Geometry - 3.26 MB - 03/28/2018 at 15:05
Download
receiver.stl
Standard Tesselated Geometry - 886.51 kB - 03/28/2018 at 15:05
Download
View all 10 files
Log In/Sign up to comment
Sign up with Github
OR
Supplyframe DesignLab: 2023 Hackada…
This how-to will show how to fit a longer bed on any flashable 3D-printer. We use the long bed ourselves to print windturbine blades.
Project Owner Contributor
XL Long bed 3D-printer conversion
fromwastetowindFromWasteToWind
A chest that could be print to be put in the pop-up book
Pirate chest
paulsprietpaul.spriet
Rescue a 3D print that needs support by stacking index cards underneath the overhangs.
Printing on Shims
andrew-dawesAndrew Dawes
A compact portable 3D printer with folding bed and removable toolheads
Resha
mo-badrMo Badr
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Warhammer 40K HANDGUN", please tell us the reason.
Send message
Remove Member
