Specs and inital designs.
Its wireless
--NRF 2.4ghz
Cheap
-No transfomer
-optio isolators
-driver chips.
Expandable
-4/8/12 channel.
-Add 2 expansion boards 4 channels at a time.
Low power
-20-30ma @ 5v consumption.
Small Form factor
-Enclose in a cheap 2inch pipe.
It should be around $17 , competing with wired diy controllers that cost $60+
Triac choosing
Figuing out what my max current rating should be.
Thinking about 10amps max now (really 12amps), Even so that bigger triac really has no use. Accept if you need extra current for one or 2 channels.
12Chan = .8 Amps Each
8Chan = 1.25 Amps Each
4Chan = 2.5 Amps Each
Current design files here.
