So here is what i ended up with once i layed the board out and set clearances. All though hole accept the micro. The reason for the smd part is very simple if i do a group buy for this as a kit its really the only component I can get a significant price break on. That would mean a lot of counting and re packaging, instead i woudl sell theses with atmegas328s presoldered and pre boot-loaded. So its super cheap to get started.
The top board is not done yet but it should be the same as the picture before.
Here is the current schmatic if anyone is intrested:
http://kneale.us/raptor12/ver3/Schmatic.pdf
03-02-2014, 06:17 PM
KingOfKYA(Travis K. )
