DHl normal takes 4 days for deliver from china to the usa:) but apparently Hong Kong customs is making thing take mutch longer, recently. Its always something...
Anyway here is some pics of the pcb:
The pci-eX1 connector that just because i need an easy way to program the micro for boot loading micros for kits. it will break away after Assembly, and no you can not plug it into your pc motherboard but you all knew that already right:)
