Today we received the items necessary for our project. We started doing the programs that would enable the muscle sensor and the servo motor to work together. What we want to achieve is the motor being able to tighten the strings on the flexi-hand using the data from the muscle sensor.
We did research on the material needed for the hand and we found that the best is FilaFlex.
