For those wanting to use the full Arduino control of the Educase I've updated the code on Github. It is now branded as the Aurora firmware for easy identification/tracking. The current build is V1.1
The controller will display our battery voltage levels, monitor temperature, issue alarms, disconnect supply and display all the good info via the trusty 5110 LCD. I'll commit the newer code updates soon!
