Loading a constant from program space
A project log for RISC Relay CPU
Scientific calculator with a brain built out of relays.
roelhroelh • 01/07/2020 at 19:53•0 Comments
Someone asked how the LDC instruction works. The LDC is needed for the Harvard architecture, were the program memory is separated from the data memory. So when you have a table of constants in program memory, you can not use a normal memory instruction to get such a constant into your processor. That is why there is a special LDC (Load-Constant) instruction.
The short version is this:
The LDC instruction uses the fact that the 12 bit program counter consists of two 12-bit wide latches. The first latch group is called the master PC, and the second latch is called slave-PC. The slave PC can be loaded with an incremented version of the master PC, and then the master PC can be loaded from the slave register to increment it. The slave PC also directly drives the address bus of the program memory.
Like most instructions, the LDC uses one of the address registers. In this case, the contents of the selected address register is loaded into the slave PC, while the actual PC value stays available in master PC. The address is now connected to the address bus of the program memory. In the next cycle, the contents of the program memory will not go to the instruction register (that will be cleared, and execute a NOP), but it will go to the DH register. Then, the slave PC is reloaded from the master PC (that still contains the programcounter value), and the next instruction will be executed as normal.
And now the detailed version:
The LDC is decoded on the Clock&Control pcb, by RL170 on the schematic. Normally, this relay is attracted but for the LDC instruction it is not. When the LDC is detected, this relay causes the following actions:
