I received the battery last saturday, and after connecting it to the charging/protection circuit I quickly discovered the circuit was getting unusually hot, so I disconnected the battery and determined the resistance between the battery connection points was near 0. Great protection circuit.
I had another one lying around that still has a usb host connector, I'll use that one and keep the usb connectors so it's easier to replace.
casplantje
