Working in this field will draw you ridicule and attract trolls. I will be simply replicating phenomena. I have a feeling that if 99% of HAD.io users were alive during the time of Orville Wright they would have laughed and pointed fingers at the fools who thought they could fly.
That being said this is a legitimate observable phenomena if you don't believe it, have fun living in a box. The experiment will use 2.0M lithium hydroxide as an electrolyte in heavy water. The electrodes will consist of nitrogen doped multiwalled carbon nanotubes bonded to stainless steel with PVDF.
I will not be doing calorimetry, as that would require a very expensive setup. I will over volt the cell to hydrolysis which will leave an excess of dueterium ions in solution and intercalate them into the cathode. At which time the cell will be placed into an ultrasonic bath and a CR-39 witness will be present to detect nuetron emission.
There will be control experiments using the same setup with distilled water, with and without sonication for to be specified time intervals.
This documentation describes Open Hardware and is licensed under the
CERN OHL v. 1.2.
You may redistribute and modify this documentation under the terms of the
CERN OHL v.1.2. (http://ohwr.org/cernohl). This documentation is distributed
WITHOUT ANY EXPRESS OR IMPLIED WARRANTY, INCLUDING OF
MERCHANTABILITY, SATISFACTORY QUALITY AND FITNESS FOR A
PARTICULAR PURPOSE. Please see the CERN OHL v.1.2 for applicable
conditions
MECHANICUS
Soham Chakraborty
Mark Kelsall
