First prototype
A project log for Waffle: a pocket-sized digital radio system
µController, CC1101 module and LCD forming a small communication device. Other probable uses in the near future.
mdasilvaM.daSilva 05/10/2016 at 11:120 Comments
PCBs are in!
I'm still waiting for the 100nF decoupling capacitors, but I couldn't wait! I already assembled the first board.
I know, the soldering job is sloppy, my trusty Weller died on me, I had to use a plain old mains powered iron... My SMD skills aren't very good either.
The ATMega didn't get recognized by the ISP at first, some pads weren't correctly soldered. After a few tries and two different programmers, I managed to get a successful flash.
The buttons work fine, OLED doesn't have any glitches, and the USB-to-Serial converter works as planned. I'm still getting some errors during the operation of the COM port, I think it has to do with the missing decoupling caps... I'll see how it goes once they come in.
Now, off to write some software and run tests!
Rich text editor
