So, everyday somebody is designing using serial2usb (ex: FT232) and a microcontroller.
Serial is simple, useful and easy to use. BUT
Problem1
Suppose, these devices have multiple functionality (ex: GPIO, SPI, I2C) but they have to be controlled over one Serial interface!.
Only the process (which opened the serial device) can use all functionality.
No two diffrerent process can control {1st process: GPIO, 2nd process: SPI} in parallel because the device use serial.
Last resort: cram all code in one process.
TADA: say bye-bye to modularity and mantainibility while saying hello to increasing complexity and bulk-code
Parallel communication is not possible/practical via using Serial because
- Serial isn't designed for that!
- usually serial2usb only provide one usb interface (or two) for serial over USB.
- Multiple serial over USB interface will convert into multiple RX+TX lines
Problem2
Inherit design of such device are not build while keeping parallelism in mind.
example: designer consider copying using CPU instead of DMA (because it is easier).
Note: CPU could have done something else while DMA is copying.
Problem3
serial2usb like IC addup cost. (they cost similar that of a micrcontroller)
Today usually all microcontroller comes with ADC, USB, SPI, I2C. These are not special parts now.
Even if USB peripherial is there, peoples are happy with implementing [serial overUSB] with it. :/
Problems Conclusion
Everybody and their dog is happy by using serial2usb like IC but not all case justify them.
Solutions
Solution to Problem1
Box0 by inherit design and implementation have concept of modules.
A Box0 device can have multiple Box0 modules.
All modules are independent of each other (there is no coupling)
So, if you familiar with "USB interfaces". all Box0 modules are provided as "USB interfaces".
Now, by taking permission from kernel, the process can communicate with the specific interface (which is a Box0 module) instead of taking control over the full device.
So, now, if there are 5 modules in a device, 5 process can control them independently. YaY!
(or 1 process can take control over 5 modules - if you want to)
AFAIF, in 90's serial was replaced by USB for such reasons.
Solution to Problem2
Since Box0 by design have parallelism and use abstract interface for communication.
even though STM32F072 is a "low end" microcontroller, using DMA, interrupt, timers like peripherial, all modules (ie USB interface) can work in parallel.
example:
- CPU initalize Timer, ADC, DMA
- CPU start timer (and goes to do something else)
- timer give trigger to ADC
- ADC after data-ready give trigger to DMA
- DMA copy the data to RAM
- goto 3 until required number of samples captured.
- done: DMA generate a completion interrupt
- CPU service the interrupt and send the data of to host (and goes to do something else)
If work is not available, CPU (only) goto "sleep"
Solution to Problem3
As you readed in solution to problem{1,2}, there is no serial2usb IC.
Conclusion
So, while reducing cost by not using serial2usb like IC, box0-v5 is more powerful because of its inherit design and implementation.
This is why, one module (example AIN) can be opened in Python while AOUT one can be opened using Box0 Studio - Function Generator
Note
Box0 USB Specification - The Box0 Design specification
box0-v5 - A Box0 Implementation
