Introduction
Today we will make a REST server using Node.js.
For this tutorial, it is assume that you are familiar Node.js & Express
API
Read Device informationURL: /
Method: GET
Response: {"name":"Box0","manuf":"Mad Resistor","serial":"A2005400E015843503134302"}
URL: /dio/0
Method: GET
Success Response: {"name":"DIO0","count":8,"ref":{"low":"0.000000","high":"3.300000"}}
URL: /dio/0/:pin
Method: GET
Success Response: {"pin":0,"name":"0","value":"low","dir":"input","hiz":"enabled"}
URL: /dio/0/:pin/value
Method: GET
Success Response: {"pin":0,"value":"low"}
URL: /dio/0/:pin/value/:value
Method: GET
Note: :value
can be low
or high
Success Response: {"pin":0}
URL: /dio/0/:pin/toggle
Method: GET
Note: Should only be called when pin is in output direction
URL: /dio/0/:pin/dir
Method: GET
Success Response: {"pin":0,"dir":"input"}
URL: /dio/0/:pin/dir/:value
Method: GET
Note: :value
can be input
or output
URL: /dio/0/:pin/hiz
Method: GET
Success Response: {"pin":0,"hiz":"enabled"}
URL: /dio/0/:pin/hiz/:value
Method: GET
Note: :value
can be enable
or disable
Common Error Response:
- Device related problem (example: communication)
Code:500 Internal Server Error
Type:text/plain
Content:B0_ERR_IO: Device I/O error
- Invalid argument
Code:400 Bad Request
Type:text/plain
Content:Invalid pin "a"
Code
"use strict";
var express = require('express')
var box0 = require('box0')
var util = require('util')
var dev = box0.usb.open_supported()
var dio0 = dev.dio()
var app = express()
function invalid_arg(res, msg) {
res.set('Content-Type', 'text/plain')
res.status(400).send(msg)
function handle_exception(res, cb) {
try {
cb();
} catch (e) {
res.status(500).send(e.message)
app.get('/', function (req, res) {
res.json({
manuf: dev.manuf,
serial: dev.serial
app.get('/dio/0', function (req, res) {
var low = dio0.ref.low.toFixed(6)
var high = dio0.ref.high.toFixed(6)
res.json({
count: dio0.count.value,
ref: {low, high}
app.param('pin', function(req, res, next, pin) {
var pin_value = parseInt(pin)
if (pin_value >= 0 && pin_value < dio0.count.value) {
req.pin = pin_value
next()
return
invalid_arg(res, util.format('Invalid pin "%s"', pin))
app.get('/dio/0/:pin', function (req, res) {
handle_exception(res, function () {
var pin = req.pin
var name = (pin < dio0.label.values.length) ?
dio0.label.values[pin] : 'CH' + pin
var value = dio0.value_get(pin)
var dir = dio0.dir_get(pin)
var hiz = dio0.hiz_get(pin)
value = {true: 'high', false: 'low'}[value]
dir = {true: 'output', false: 'input'}[dir]
hiz = {true: 'enabled', false: 'disabled'}[hiz]
res.json({pin, name, value, dir, hiz})
app.get('/dio/0/:pin/value', function (req, res) {
var pin = req.pin
res.json({pin, value})
app.get('/dio/0/:pin/dir', function (req, res) {
var pin = req.pin
res.json({pin, dir})
app.get('/dio/0/:pin/hiz', function (req, res) {
var pin = req.pin
res.json({pin, hiz})
app.get('/dio/0/:pin/toggle', function (req, res) {
var pin = req.pin
dio0.value_toggle(pin)
res.json({pin})
app.get('/dio/0/:pin/value/:value', function (req, res) {
var pin = req.pin
var value = String(req.params.value).toLowerCase()
value = {'high': true, 'low': false}[value]
if (value === undefined) {
var msg = util.format('Invalid value "%s"', req.params.value)
return invalid_arg(res, msg)
dio0.value_set(pin, value)
res.json({pin})
app.get('/dio/0/:pin/dir/:value', function (req, res) {
var pin = req.pin
value = {'output': true, 'input': false}[value]
dio0.dir_set(pin, value)
res.json({pin})
app.get('/dio/0/:pin/hiz/:value', function (req, res) {
var pin = req.pin
value = {'enable': true, 'disable': false}[value]
dio0.hiz_set(pin, value)
res.json({pin})
app.listen(3000, function () {
console.log('Listening on port 3000!')
process.on('SIGINT', function() {
console.log("\nGracefully shutting down from SIGINT (Ctrl+C)")
dio0.close()
dev.close()
process.exit(1)
Interacting
You can use your Internet Browser / telnet
to interact with the REST server.
Get device information
Request: GET /
Get DIO0 module information
Request: GET /dio/0
There are 8 pins for this device with low voltage 0V and high voltage 3.3V
You can reference 8 pins via 0, 1, 2, ... 7
Turn On LED on pin number 3
Requests:
GET /dio/0/3/dir/output
GET /dio/0/3/value/high
GET /dio/0/3/hiz/disable
Your led will blink
Reading from pin 4
Requests:
GET /dio/0/4/dir/input
GET /dio/0/4/hiz/disable
GET /dio/0/4/value
Resonse (from 3rd query): {"pin":4,"value":"low"}
This tells that pin 4 is LOW.
Toggle pin 3 value
Requests:
GET /dio/0/3/value/low
GET /dio/0/3/toggle
GET /dio/0/3/toggle
GET /dio/0/3/toggle
and continue toggling it!
