in a I spent a large amount of the weekend working on several ways to make pulleys or at least power transmission with what was available to me.
Sadly, I didn't make it. Hopefully, you can still have some fun looking at the fails !
This first collage shows you how I thought I could use one belt to drive another one. On the big picture at the bottom you can see that the belt does not match the pulley. Which now that I thought about it absolutely makes sence. It would require the radius of the pulley to be infinite to work.
To give a positive note to this post, I still have made some progress on the architecture but those failures plus other problems raise questions on the design. I will pursue on this first prototype until the end of the Anything Goes contest since it will probably raise other issues that I can take into account while designing the second prototype.
Alain Sanguinetti
