I found a cheap USB keyboard controller chip! It is the Holtek HT82K629A. It requires a minimum of passives, plus a 6MHz crystal, and you're done -- just hook it up to USB and it looks like a standard keyboard.
You don't get to say which key is which: a given intersection of row and column is hardwired to be a given key. I've hooked up the "1" key. When I plug it in to my computer, it works great. I can type 1's all day. So now I don't need an FRDM board to run the keyboard.
Hello, how did you do it with drivers? Ive tryed to set up the same as you, but my computer does not seem to recognize the device, do you have any tips?
I ordered one. I also ordered some tactile buttons. I'll find out how small qwerty-keyboard I could make out of these.
