Conversion to Vivado has been started, it does pass syntax check, but some modules are still disabled as initial workaround.
ISE only supports A100T and A200T, and not many newer devices so Vivado porting is necessary at the end of fhe day.
A project log for MEGA65 - OPEN 8-BIT COMPUTER
MEGA65 is an open-source new and open C65-like computer. Hardware designs and software are open-source (LGPL).
