Soviet MP-transistors are relatively easy to open:
First of all you need pliers to hold a head of transistor like this to avoid damaging of semiconductor joints inside:
Then you need to squeeze the head to break it:
A project log for Germanium Vision
Low-resolution video camera with a lot of opened germanium transistors used as light-sensitive elements
