There are a couple of issues to overcome with the Smart EV drivetrain being retrofitted into my Eclipse, Firstly, the motor mounts are of course wildly different so I've had to grind off the left side mount to make room. A new mount will be fabricated for this spot..
I'll also fabricate a mount for the other side, both will be welded to the subframe.
Next issue is that the electric drivetrain gearbox will only work in one orientation, or else it will leak oil out of it's vent hole and the gears will not be correctly lubricated by the built in oil channels. This means the differential must be on the other side of the engine bay. Unfortunately it collides with the suspension crossmember (which has an indent for the original gearbox differential)
To check alignment I ran a string from the center of one wheel to the other and used a laser line to indicate the axle center. Need to get this as close to central as possible to reduce loss in the CV's
Jarrod
