I was finally able to successfully install “Apache Maven”. My main issue was figuring out how to edit my laptop system PATH's so that I could use Maven in command line (console) from any directory.
After getting Maven to work I was finally able to build “.jar” file from the VLCJ files I downloaded. So I :
- Downloaded and re-installed Java JDK
- Downloaded and installed Eclipse IDE for Java
I'm having issues getting the application to run, build was successful and created a .jar file with the correct name but doesn't work when I try running it from Eclipse or writing and running a .bat file that calls it.
Built 3.3v regulator board on stripboard and cleaned up my bare TGAM1 board (shrinks size of module considerably).
