Switching to using JavaFX to design video/media player. Still learning Java and how to use JavaFX Scene Builder but finally making some good progress. initially I was using Eclipse to write and debug code but finally switched to NetBeans (mainly because there is more tutorials and documentation available). Also using the code in the Brainflex project on GitHub to understand how to parse the serial data coming from the EEG signal.
