Inhibit Line Driver
A project log for Ferrite Core Memory Module
A sub-project of the ED-64 Computer to document the development of a 64-byte ferrite core memory module
andrew-starrAndrew Starr • 04/19/2017 at 08:39•2 Comments
As I think I mentioned previously, I was using a X/Y line driver module to drive the inhibit lines - forgetting that since only one H-bridge could be active at a time, at most only a single '0' could be present when writing a byte to memory. Some hasty adaption of the X/Y line driver, and we have the Inhibit Line Driver, Rev A. The PCB arrived today:
Now I'm just waiting on some 2512 SMD resistors...
Andrew Starr wrote 04/19/2017 at 09:10 • point
2512 is a size code, not a quantity :)
Yann Guidon / YGDES wrote 04/19/2017 at 09:03 • point
2512 resistors ???
