A while ago I wrote an assembler, and an emulator for the arduino that allows it to emulate the ED-64 instruction set (such as it is). Now that the FC memory is functional, I have modified the emulator to use it as the program and data store (instead of the arduino internal memories).
The output of the assembler is a header file which contains the assembled ED-64 program as an array of constant unsigned chars. When the emulator is loaded into the arduino, it includes the header file. During the setup phase of the emulator, it loads the program array into the FC memory. The program can then be inspected, single-stepped, or executed.
Here's a very short test program:
JCC start
add1:
db 0x27
add2:
db 0x43
sum:
db 0x00
start:
SAC sum ; clear accumulator
ADD add1 ; add 0x27 into accumulator
ADD add2 ; add 0x43 into accumulator
SAC sum ; store result into sum
loop:
JCC loop ; now loop foreverHere is the assembly output:static union
unsigned char data;
struct
unsigned char operand : 6;
unsigned char opcode : 2;
} instr;
} mem[64] =
0xC4,
0x27,
0x43,
0x00,
0x83,
0x41,
0x42,
0x83,
0xC8,
};Inspecting the program via the emulator (before execution):
The yellow box indicated the numbers to be added at locations 0x01 and 0x02. The red box is the destination memory location 0x03.
After starting execution (and interrupting the endless loop to inspect the memory):
Location 0x03 now holds the result of our calculation, 0x6a.
Temperature is still an issue. I found I needed to occasionally tweak the biases on the sense amps as the room warmed up in the late morning/early afternoon. I may eventually do something about this, or I might not. My priority now is the rest of the computer.
Andrew Starr
Yeah man :) Things should move ahead (relatively) rapidly now that the major R&D is over, the rest is just logic modules!
yeah, "it's just logic", that's what they all think hahahaha :-P
It's alive ! ALIIIIIIVE !!!!
