This the first test run for the relay.
This is with the contact gap adjustment screw added and the relay connected between IO and the typewriter/printer for a slow test.
A project log for Cardboard Relay - Uglytech is getting better
A relay constructed from materials found in the home and will hold up to actual daily use.
Thanks Yann :-) The current is still very high at 400 ma but just using enough coil turns to make it work. Needs more turns to bring that current down to something practical ;-) Also finer wire would be better as this is 28ga. Diode is in there.
That's so awesome :-D
What's the coil current ? Do you have a freewheel diode ?
