RF based Universal Remote Control
RF based remote control for TV, Set-top Box, etc.
This is an RF based remote control for TV, Set-Top Box, or any IR controlled appliance. The remote appliance can operated using software installed on any Smartphone.
This project contains two boards with RF modules, Transmitter and Receiver. The Receiver is installed in front of the appliance to be control. The Transmitter connected to the smartphone. This remote has a learning capability, it can copy the code of any IR based remote control.
IR Transmitter module
JPEG Image - 2.06 MB - 04/28/2016 at 06:49
Preview
IR Reader Module
JPEG Image - 2.12 MB - 04/28/2016 at 06:49
Preview
Receiver Module - Kept in front of device to be controlled - RF module receives the IR code - The controller board decode the code - Emits IR signal
JPEG Image - 2.28 MB - 04/28/2016 at 06:43
Preview
Transmitter Module - Connected to Mobile - IR reader detects the IR signal - The controller encode & saves the IR code - RF module transmits the IR code
JPEG Image - 2.37 MB - 04/27/2016 at 13:43
Preview
RF Module - Works on 2.4GHz - RF Transceiver
JPEG Image - 2.16 MB - 04/27/2016 at 13:41
Preview
View all 6 files
  • 2 × Microcontroller Board
  • 2 × RF Module
  • 1 × IR Receiver
  • 1 × IR Transmitter
  • 2 × Battery Evaluation, Demonstration Kits, Boards and Modules / Evaluation Kits, Boards and Modules
  • Mobile Application
    Parag Bagde • 04/28/2016 at 06:37 • 0 comments
    Yet to start.......
  • Hardware Design
    Parag Bagde • 04/28/2016 at 06:35 • 0 comments
    The prototype design of the project is tested and ready for demonstration. The final product design(Schematic & PCB) is ready, but not fabricated.
  • Firmware Coding
    Parag Bagde • 04/28/2016 at 06:30 • 0 comments
    The firmware code for Transmitter and Receiver is completed.
    For Transmitter, the firmware code functions, RF communication, IR code detection & learning, and serial communication.
    The Receiver firmware functions, RF communication, IR code generation.
    The firmware is tested on PC based application written in C#.
View all 3 project logs
