Possible inputs:
- DC power: 1 to 600 volts, up to 400W and 75A,
- AC power: 20 to 240 volts, up to 400W and 20A,
- Fluid flow: upper limit of 50 PSI,
- Spline drive: 5.25 ft-lbs @ 500 RPM to 0.875 ft-lbs torque at 3000 RPM (1/2HP)
Storage capacity:
- 120 Ampere-hours, with provision for additional external storage
Possible outputs:
- 3 USB ports -- up to 6.3A total
- Copper stud (M6 / 1/4 in)
- Universal AC outlets at 120/240VAC 50/60Hz
- Tesla turbine fluid pump (input as inlet to output; water, air, non-corrosive fluids and gases)
- Spline drive: 5.25 ft-lbs @ 500 RPM to ft-lbs @ 3000 RPM (1/2HP)
Displays and controls:
- LED indication of power input and output levels
- LED indication of internal power storage level
- Push-button selection of inputs and outputs (multiple choices allowed)
Packaging:
- IP65 sealed case with external cooling fins.
- Epoxy finish
Do you like power? Do you like portmanteaus? Do you like things that are fantabulous? Great!
The People-Power to People-Power Universal Power Converter takes different kinds of energy and turns it into the kind of energy you need. Energy may not be created or destroyed, but it can be transformed!
This device is useful in all kinds of applications, whether you're in a developed or developing country. Take power in the form of electrical, fluid, or rotating mechanical energy and convert it into the same or another form of power. You can also store that power in an internal or external storage device, such as a battery or super-capacitor.
Constraints on inputs and outputs are flexible, and they are protected from light abuse such as reverse-polarity and shorted outputs.
The goal of this device is flexibility and versatility, and promoting the ability to use energy in many forms from multiple sources.
