It seems with the new status bar on top the info bar at bottom has stopped updating. Very strange. The bottom is still made of up a container with textboxes. In thinking through the next design steps it didn’t make sense to spend time on fixing this issue since the graph needs to be converted into a widget and will change the bottom info bar.
MobileWill
