So with the added Crystal and the two capacitors for it, I think it is ready now. You can see it right side of the Microcontroller on the image. The Crystal is a 2016 package and the two capacitors are 0201 (I hope I will get soldered that). The silkscreen marking looks also nicer now.
On the top side there are no big changes.
