In the last log I wrote about a quite complicated way to load images to the display. I now have improved the octave script. it no loads the image itself to the display:
This is done by using the instrument-control package of octave:
function IMG_test
pkg load instrument-control
if (exist("serial") != 3)
disp("No Serial Support");
endif
myImage = imread("image.png"); #read 8x8 pixel image
# the image is vreatet with MS paint. At least there each
# pixel is encoded into three bytes (R,G,B) this could be
# normal for png. At least I hope so
# now to the conversation magic
red = uint8(bitshift(myImage(:,:,1), -5));
green = uint8(bitshift(myImage(:,:,2), -5));
blue = uint8(bitshift(myImage(:,:,3), -5));
#add the three colors to one byte togehter
img8trueColor= bitshift(red,5) + bitshift(green,2) + blue;
#transpose the image - needed to save it correctly
img8trueColor=img8trueColor.';
#write it to display direct in octave no more a file output
s1 = serial("\\\\.\\COM12");
set(s1, 'baudrate', 38400);
srl_flush(s1);
srl_write(s1, img8trueColor);
endfunctionThe source code is also in the github repository. helpful links for octave and uart:
http://wiki.octave.org/Instrument_control_package
http://www.edn.com/design/analog/4440674/Read-serial-data-directly-into-Octave
http://projectsfromtech.blogspot.de/2015/03/serial-port-communication-with-gnu.html
Alex
