First test
A project log for OneWireKeypad adapter
A simple board to convert matrix keypad with 8 pins to use only one ADC pin and VCC-GND.
malhar-deshmukhMalhar Deshmukh • 04/24/2016 at 16:37•0 Comments
Tested with 5.1K row resistor and 1K column resistor
Result:
keys 1 to 9 work. As we move to down right corner, the stability decreases. May need to tweak resistor values.
