I have done some testing with the STM32duino USB bootloader. A bootloader enables the user to upgrade the firmware of the cartreader via USB without the need for a special programmer. The bootloader is active after the device is powered up or when the reset button is pressed. dfu-utlil can be used to flash on the firmware.
Koen van Vliet
