Hackaday.io Hackaday.io
Sign up Log in
portable pluggable YAGI Design
antenna design based on a 3D-Printed quick lock mechanism
thomas-pointhuberThomas Pointhuber
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.9k views
0 comments
29 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
2.9k
0
29
21
Team (1)
  • thomas-pointhuberThomas Pointhuber
Join this project's team
  • portable_yagi_v1
hardware
ongoing project
Antenna Yagi ham radio
This project was created on 04/24/2016 and last updated 10 years ago.
Description
This is my first approach to build a 70cm Yagi (based on the design of DK7ZB: http://www.qsl.net/dk7zb/PVC-Yagis/7-Ele-70cm.htm) using quick lock connectors.
Because of that, the antenna can be assembled on field without any tools or tiny parts which could get lost.
Because this is a test object, the parametic part is not so simple as it could be. Later, I want to release parametic OpenSCAD parts which can be simply used to create custom quick lock based Yagi designs.
Project Logs
Collapse
  • initial design files published
    Thomas Pointhuber • 06/04/2016 at 14:46 • 0 comments
    I reworked some files, created endcaps and feel like I could publish the first version of the yagi design.
    The files now can be found on my github repository: https://github.com/pointhi/oe5tpo_antennas/tree/master/portable_yagi_v1
    Please look onto the README.md file, because the models are specific designed for my printer, and probably need adjustances of the tolerances (otherwise the modules wouldn't hold on the rod).
    This is how the new designed endcap looks like. Now a fully assembled antenna looks pretty professional:
  • second version completed (2m version with better parts)
    Thomas Pointhuber • 05/21/2016 at 19:28 • 0 comments
    I finished my second yagi antenna using this quick lock system.
    It's a 4 element yagi for 2m, with about 7dB Gain (Design from DK7ZB: http://www.qsl.net/dk7zb/PVC-Yagis/4-Ele-2m.htm)
    Furthermore I improved all 3D-Printed-Parts, to fix some issues like to thin walls or to little mechanical stability of the radiator. The rewrite also helped me to cleanup the project, so I should be able to publish it soon.
    New version of radiator clamp
    New Version of director clamp
    I verified the design by receiving Delfi-C³ in a distance of about 1500km. I heard either the CW Baken, or the BPSK Telemetrie downlink on 145.870 MHz, using a UV-5R as receiver.
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
The 2017 Hackaday Prize
Original design v-tail quadcopter, all pieces 3D printed. 2213 935kv motors running 10.5 inch props with a 4400mah battery.
Project Owner Contributor
Raptor V-Tail Quadcopter Drone
kendoken.do
This is a project inspired by @andrias, We will try to print it and later edit the design.
3D printed robotic arm
abd-el-rhmanAbd-el-rhman
A write up on my design process for an entry into the Linus Tech Tips and SilverStone Headphone Stand Design Contest
Wall Mounted Headphone Stand
taibhse-designsTAIBHSE DESIGNS
These are some of the models and parts I have made.
Solid Models
isaac-s-gentryIsaac S. Gentry
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "portable pluggable YAGI Design", please tell us the reason.
Send message
Remove Member
