It's alive!
A project log for DC-10
My implementation of C10 decimal time clock
danjovicdanjovic • 11/28/2016 at 03:38•0 Comments
The assembled board is now working! It was necessary to change the code to match the common cathode displays. I am considering to add a compiling directive to select whether to use common anode or common cathode.
The green display was too dim with the original 560 Ohms resistor. I needed to change them to 150 Ohms and the brightness is much better now.
Both the prototype and the finished board are working now.
