The Pit Sparker
A High Voltage Deodorant.
This is a stun gun-like device disguised as a deodorant stick. It was built out of cheap components from Ebay, an Old Spice Classic plastic container, and some hand-moldable plastic.
Unfortunately, because I did this project a while back without any thoughts of sharing it at the time, I don't have any pictures of the process. However I took some pictures of it pulled apart in an attempt to show how it was assembled, and I also drew up a schematic of the wiring for clarification.
Disclaimer: I don't know all that much about electricity or electronics, and this project is for entertainment purposes only. I won't be responsible for anything resulting from the use of information provided here.
  • 1 × DC 3.6V-6V 700KV Boost Step-up Power Module (inverter/step-up transformer)
  • 2 × UltraFire 18650 3.7v “5800mAH” Rechargeable Li-ion Battery
  • 2 × 18650 Battery Holder
  • 1 × Blue 12V LED Dot Light Round Rocker Toggle Switch
  • 1 × 12mm Push Button Momentary Switch
View all 7 components
Rich text editor
