Enter the Silicon Labs "Sensor Puck" which includes a dual-mode light sensor which can measure ambient light, UV light for UV exposure accumulation, and when you place your finger over the plastic-covered LED assembly (at the bottom of the Puck), it changes modes and goes into pulse rate monitoring (ala FitBit).
https://www.silabs.com/products/sensors/Pages/environmental-biometric-sensor-puck.aspx
The Puck is a bit too large to wear, but it's only a demonstration platform. Here is the back side where you see a CR2032 battery, and at the top the Bluetooth Chip:
Grayson Schlichting
