This elf is molded using Sculpy clay, 3d scanned and printed with holes for pipe cleaner legs and arms. The elf is painted and clothes are hand made. Instructions for doing this can be found here.
The swing is operated using a servo motor. The base is made using wood and the swing itself is 3d printed. Files can be found here.
