I removed the right rear panel and connector, then Annelle painted them, then they were restored to position. It was a good test of the modular nature of the display--took about an hour to remove and another hour to restore.
Santa is temporarily "out of the box" for servo wire extensions. Connectors will have to be made and an Arduino programmed (and a hole cut in the floor of the display box) for Santa to become active.
