Hackaday.io Hackaday.io
Sign up Log in
I/O Pin Testing & Observing
paul-stoffregenPaul Stoffregen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
37 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
591
0
37
7
Team (1)
  • paul-stoffregenPaul Stoffregen
Join this project's team
  • Project Blog
This project was created on 02/18/2014 and last updated 8 years ago.
Description
I do a lot of testing on Arduino libraries and sketches. Being able to quickly observe and fiddle with ALL the pins makes this much easier.
I wanted a board that shows the state of all I/O pins on LEDs with all of these properties....
Works for Digital Input, Output, and Input Pullup
Pushbutton to drive the pin high, very weak pulldown (much weaker than on-chip pullup)
Works for analog pins (thumbwheel pot), but also works when the same pin is used for digital
LED shows actual analog level - LED current should be linear to actual voltage
LED current does not interfere with analog voltage
LED does not interfere with weak signals, or input pullup or pulldown
Inexpensive - under $0.50 per pin - many parts are ok, as long as they're cheap!
More details on my DorkbotPDX project blog...
Project Logs
Collapse
  • PCB Files & Placement Diagram
    Paul Stoffregen • 02/25/2014 at 20:30 • 0 comments
    ​I've added the PCB gerber files and placement diagram for the latest version of this board, on this project's blog page at DorkbotPDX.org
    http://www.dorkbotpdx.org/blog/paul/input_output_a...
    I would post them here too, if this site had a way to attach the files...
View project log
Log In/Sign up to comment
Sign up with Github
OR
Supplyframe DesignLab: 2023 Hackada…
An Arduino UNO Compatible Board with isolated Glowing headers and some Extras
Project Owner Contributor
Uno Plus+
john-loefflerJohn Loeffler
The Healing Heart is a conflict-resolution tool which teaches children to apologize in a way far superior to most adults.
Project Healing Heart
grant-stankaitisGrant Stankaitis
I'm building a prototype 4x4x4 LED cube with a charlieplexed topology.
LED cube using charlieplexing
endevor100endevor100
This project features a custom 3D-printed 'Mortal Kombat' trophy shell paired with a basic NE555 timer circuit in 'astable mode',
3D Printed Breathing IC555 LED Trophy
hulkHulk
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "I/O Pin Testing & Observing", please tell us the reason.
Send message
Remove Member
