I finally got to take some good readings from my oscilloscope program on the JDEPC-ov04 camera in my spectrometer, it doesn't work when the camera is running, but I can get good data on dB levels when it is at rest and on stand-by for data capture.
I did a low pass and a high pass scan:
This is the low pass scan in dB levels at rest.
