We apologize for the radio silence however we have still been hard at work the the microscope. Apollo hs designed a 3D printable mount so you can adapt the Pi camera to a standard microscope. Files are "top of camera mount.stl" and "bottom of camera mount.stl".
quick note on assembly: The camera works best with a microscope if you remove the lens from the camera before assembling. The assembly used standard 3mm hex head screws for assembly and a piece of double sided tape on the top of the camera board to finish out.
We will be posting a few nice still shots of the camera in action in a up and coming project log. We have a meeting tonight to work on the UI of the remote feed and integration of the stepper control.
*Please be aware all of a the files are in a prototype stage so be carefully using them as they are subject to change.
