Cut a wood box, to get all connections together and to plan how place all in a more fancier box, problem is ATX PSU is huge and it's placed outside, might switch it for a ITX PSU with a more smaller foot print. Also included wiring for TV energy supply, but got a connector a little to small, it works, but only nudging it a little to the bottom.
This usb outlet provides only power to the rPi.View of inside the box:
Close up of some of the wiring:
Little switch to start things up:
