Hi Everyone,
I am glad to announce that I have created a few FPGATED devices (HW ver 3.0) which are available for sale! As this is still a development, these are available in a limited number for those who are interested and are willing to do tests and report any issues.
The board perfectly fits in a C16 and Plus4, however in the Plus4 due to space limitations a 90 degree HDMI connector cable must be used (right angled to straight).
I use the following one: https://www.aliexpress.com/item/1005006299127375.html
I recommend to replace the 48 pin IC socket of the C16 with a precision one as it requires strong force to insert the board in the factory socket. However if that is not a possibility, it is ok to use in the original socket too.
The installed firmware and SPI flash includes a configuration software I have written, but at the moment using it requires a short starter code that I will share later.
If you are interested please send a mail to info@fpgated.hu for contact and price details.
István Hegedűs
