The Sowing and soldering Job on Prototype No.1 is finished.
I made 60 pokets for 60 Vibration Motors and wired them all up to a pcb, where i plan to mount the Raspberry Pi and the 2 Borads with each 32 channels of PWM (12bit).
The two expansion boards are ordered and i am currently working on the software side.
Have you considered using another kind of sensor, such as a eltromagnetic sensor or a humidity sensor so you would have kind of a new, nonhuman, sense?
