I have finished making the belt of the WorkHorse 3D Printer and I ran a few quick 3D printing tests.
I need to make multiple adjustments to the firmware to finalize the machine. For example, the y axis movement is not proportional. The printed object should be circular.
I would also like to give a shoutout to the Deltesian project. The Deltesian is an open source 3D printer designed by a crew of extremely knowledgeable and friendly hackers. I've spent a lot of time communicating with the team on advice and queries about 3D printing.
hi! ,
im working on a similar project i want to know how does the belt stepper command work, is it with Gcode
