Ultrasound Phantoms: War were declared
Doing a bit of research, I found that PU could be used for nice phantoms, having acoustic impedance close to that of water.
I tried two types (hard and soft, respectively PX90 and PX30) - and casted them into a silicon mold for financiers.
Tried different layers of hard/soft, including some coffee grounds for diffusers.. curious to see that these will yield.
Really curious to see what they'll give.
Thanks to Janice, here's a cool recipe for ultrasound gel.
I messed with the recipe awhile and came up with a very nice slightly caramel tinged ultrasound gel this way:
And the movie :
"This paper describes design of a low cost, ultrasound gel from local products applying aspects of Human Centered Design methodology. A multidisciplinary team worked with clinicians who use ultrasound where commercial gel is cost prohibitive and scarce. The team followed the format outlined in the Ideo Took Kit. Research began by defining the challenge "how to create locally available alternative ultrasound gel for a low-resourced environment? The "End-Users," were identified as clinicians who use ultrasound in Democratic Republic of the Congo and Ethiopia. An expert group was identified and queried for possible alternatives to commercial gel."
#BOP #Jugaad #JusteCool
Source: http://journals.plos.org/plosone/article/asset?id=10.1371%2Fjournal.pone.0134332.PDF
One of the identified issues with current DIY phantoms is that they're essentially made of growth medium (gelatin in water/agar). A well kept standard DIY phantom may last 10 days before it is overcome by mold. This can be enhanced a little bit by wiping it down with bleach (other cleaners appeared to break down the phantom), but it is ultimately a losing battle.
Breakdown is a pretty big issue as the surface of the phantom is critically important. Small, almost invisible imperfections, can cause apparently massive surface artifacts in an ultrasound. Two types of imperfections are really intrusive, but they're ultimately due to the same issue: Boundary Transition. Every time sound crosses a transition between objects with differing levels of sound transparency (speed of sound through the medium), some of the sound is reflected. The ultrasound imager relies on these reflections to visualize (it's literally the principle behind ultrasound imaging), but starts to have difficulty visualizing objects beyond the transition (less transmitted signal to utilize).
For this reason, surface imperfections are to be avoided as much as possible.
So, to start, I'm going to look at biocidial, but relatively innocuous substances to make the phantoms. On the list are bleach and vinegar, added to the water.
Some articles:
On materials, we have :
Some videos
Thanks for setting up this project.
By chance are there some tips to make heart and lung phantoms for training with a A-mode ultrasound?
It would be fantastic if it included phantoms for COPD and heart failure.
I used to make gelatin ultrasound phantoms. A few differences from your approach:
1) I used boric acid as an antifungal agent. Took a few weeks before mold grew on the phantoms. I don't remember the exact concentration.
2) I siphoned the mixed liquid gelatin into the molds to eliminate the froth on top. I just used very flexible PVC tubing; this would also cool the gelatin as it went into the mold.
3) I think I used way more powdered gelatin but as I don't have the recipe I can't say for sure.
Awesome feedback, and quite surprising! I stalked you a bit and couldn't find a reference to ultrasounds... where did that happen? Interested in joining this start of a project? =)
The relevant project : http://www.ncbi.nlm.nih.gov/pubmed/17729376
Unfortunately I got other things on my plate but I can certainly comment.
Really long day. Thanks tons for getting this set up. Also, thanks for doing better in English than I did in French (I tried. I'm the only one in my family that isn't fluent...)
OK, I'm going to hit the store and start getting gelatin. The trick is going to be finding the right combination of gelatin and bacterial growth inhibitor. Along the way we'll find techniques for various inclusions (Penrose drains for veins, grapes for "tumors", etc). I need to find an ultrasound system down here that I can test on. I'll go back and talk to the hospital. What I need from the community (you folks!) is feature requests, bug reports, etc. How deep of a phantom do you need?
idea - conserve the gelatin the way pickle jars are conserved
nevertheless, ultrasound works on difference between materials....unless it's gas or solid thing(bone)...you don't necessarily need gelatin for testing an ultrasound.banana in a water/cream will do.
