It should be noted that these boards are a fail because of noise on the analog pins (as it stands I am reading amperage in intervals of 0.07A, and the boards consistantly read 0.14A when there is no current present). I will tie the ground down better, but I am going to have to review sparkfun's tutorials and find out how they cover the board with copper for the gound.
