Spent some time playing with this in various configurations, but it is inconsistent at best due to the weak magnetic signal from the meter. I want to order a few different Hall Effect sensors and log the data, but I will also try a photo reflective sensor.
Source:
http://www.instructables.com/id/Monitoring-residential-water-usage-by-reading-muni/?ALLSTEPS
