The board is ready to use, but only the Z axis of the accelerometer is connected by default. We have to connect the others axis by soldering :
Once all axis connected and battery plugged, the board is positioned in the running belt :
After placing the electrodes and turn on the board, you can see an electrocardiogram by using Android app Bitadroid (GitHub link) for example :
